ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
antinode
Aug 12, 2021Guru
> [...] it just tells me no ethernet cable is plugged into the router
> internet port. [...]
But there is? And the other end of that cable goes where? And that
device is known to work? Which was determined how?
> [...] I have tried everthing [...]
Not a useful description of anything. You have a chain of stuff,
where at least one piece doesn't work. Test/swap each piece?
- ballbearingAug 12, 2021Aspirant
The internet which works perfectly is plugged into the yellow input of the router and the cable output is going to the PC.I really don't know what you're asking but it works when I bypass the router. When plugged into the router. the router login just says no internet. Simple as that.
- michaelkenwardAug 13, 2021Guru - Experienced User
Is there a modem of some sort in front of this router?
- ballbearingAug 13, 2021Aspirant
Of coarse, it's a Netgear also, working fine straight out of it but nothing out of the router, just the error no internet plugged into the input.
