ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
antinode
Aug 11, 2021Guru
> [...] it just tells me no ethernet cable is plugged into the router
> internet port. [...]
But there is? And the other end of that cable goes where? And that
device is known to work? Which was determined how?
> [...] I have tried everthing [...]
Not a useful description of anything. You have a chain of stuff,
where at least one piece doesn't work. Test/swap each piece?
ballbearing
Aug 12, 2021Aspirant
The internet which works perfectly is plugged into the yellow input of the router and the cable output is going to the PC.I really don't know what you're asking but it works when I bypass the router. When plugged into the router. the router login just says no internet. Simple as that.
- michaelkenwardAug 13, 2021Guru - Experienced User
Is there a modem of some sort in front of this router?
- ballbearingAug 13, 2021Aspirant
Of coarse, it's a Netgear also, working fine straight out of it but nothing out of the router, just the error no internet plugged into the input.
A Netgear what? Does it have a model number?
Over the years, Netgear has made dozens of modems and modem/routers designed for particular types of Internet. Working out where your network goes wrong depends on knowing in detail what you are struggling to tame.
Please provide as much detail as possible. Leave it to us to decide what is relevant.
ballbearing wrote:
... working fine straight out of it but nothing out of the router
What does that mean? You can plug something into this magic box and connect something or other to the Internet?
Plenty of things that could go wrong there. But we need details.
The good news is that these things are usually pretty easy to fix. You just heed to go about it methodically.
