ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
ballbearing
Aug 12, 2021Aspirant
The internet which works perfectly is plugged into the yellow input of the router and the cable output is going to the PC.I really don't know what you're asking but it works when I bypass the router. When plugged into the router. the router login just says no internet. Simple as that.
michaelkenward
Aug 13, 2021Guru - Experienced User
Is there a modem of some sort in front of this router?
