ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
michaelkenward
Aug 13, 2021Guru - Experienced User
ballbearing wrote:
The internet which works perfectly is plugged into the yellow input of the router and the cable output is going to the PC.
Is there a modem of some sort in front of this router?
ballbearing
Aug 13, 2021Aspirant
Of coarse, it's a Netgear also, working fine straight out of it but nothing out of the router, just the error no internet plugged into the input.
