SullyMonster
Sep 13, 2017Aspirant
Etekcity Wi-Fi Outlet with Nighthawk x4 R7500v2
I just upgraded from the router Charter gave to the Nighthawk. On the old router I had smart plugs that worked no problem. I've gotten everything else set up just fine on Nighthawk except the plugs! ...
- Sep 14, 2017
> Etekcity Wi-Fi Outlet [...]
Do these things have a model identifier?
Are the wireless credentials (SSID, passphrase) the same on the new
router as on the old, or different?
> [...] I try to set the plugs up and the configuration just times out
> when trying to connect to wifi. [...]
Not a very detailed description of what you did.
I've never dealt with an Etekcity socket, so I know nothing, but I
have done a little with some Orvibo S20 sockets. The Orvibo S20 has a
reset function (hold button until indicator LED flashes red). If the
Etekcity socket has something similar, then I'd try that. It also has
two methods for getting it to connect to the wireless network. If the
Etekcity socket is similar, then "I try to set the plugs up" is toovague to be very useful.
michaelkenward
Sep 14, 2017Guru - Experienced User
What are these smart plugs?
