KTWinATL
May 26, 2021Aspirant
Ethernet & WiFi SSID
How do I get my Ethernet network name to be the same as my wifi SSID? Or are they suppose to always be differetn?
May 26, 2021Guru - Experienced User
the ethernet name is set by windows (if you're on windows).
You can change it but it requires a registry edit.
registry edits=danger, dragons be here
- KTWinATLMay 26, 2021Aspirant
This for the router and not the adapter. I repeat this is for a Netgear R7000 Nighthawk Router.
- plemansMay 27, 2021Guru - Experienced User
I understand you have an R7000.
But the network name through the ethernet interface is set by windows, not by the router.
the router only sets the ssid name.
- KTWinATLMay 27, 2021Aspirant
Ok, so this shouldn't be affecting my Internet connection with Xfinity/Comcase. My connect with my ISP goes down once every 24 hours it seems like. I don't my connection can go more than 72 hours before dropping.
