PTJOHNS100's avatar
PTJOHNS100
Follower
Jun 16, 2021
Ethernet cable not working with S8000
I am having trouble with my ethernet connection.  When I put testing equipment on both ends of the ethernet cable it cycles through all 8 lights.  When I connect the cable from my GS810EMX to my GS808E I get no signal.  I tried connecting my computer directly to the GS810EMX and still no signal.  I ran a new cable across my yard.  The ethernet cable cycles through all 8 lights when tested.  I plugged it into the GS810EMX and GS808E and the signal is good.  If the old cable tests 'good' by cycling through all 8 lights on the tester, how can the newtork signal not work on that cable?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so there may be useful responses here. However, switches are not like routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Pro Gaming Switches - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
