OmarAttaalla
Apr 14, 2018Aspirant
Ethernet connection on my Windows 10 desktop keeps disconnecting and reconnecting
I recently bought a Nighthawk R7000 router modem and whenever I would use ethernet connection on my desktop it would disconnect for a few seconds and reconnect every couple of minutes. I contacted s...
- Apr 30, 2018
Hi OmarAttaalla,
What is the firmware version of the router? Make sure it is updated.
IrvSp
Apr 15, 2018Master
Are you using a 'fixed' IP Address on the PC? That is in the properties you've assigned an IP Address to the Ethernet Adapter?
When the PC is connected, what does the ATTACHED DEVICES show? Both the PS4 and PC or just one?
When the PC is connected open a COMMAND PROMPT and enter IPCONFIG /ALL and copy the results and paste it into a reply.
