OmarAttaalla
Apr 14, 2018Aspirant
Ethernet connection on my Windows 10 desktop keeps disconnecting and reconnecting
I recently bought a Nighthawk R7000 router modem and whenever I would use ethernet connection on my desktop it would disconnect for a few seconds and reconnect every couple of minutes. I contacted s...
- Apr 30, 2018
Hi OmarAttaalla,
What is the firmware version of the router? Make sure it is updated.
IrvSp
Apr 15, 2018Master
I'd say ENABLE logging on the Router (IF you can reach it via the PS4 or another device) and check all boxes. Set the schedule to for EMAIL to send it to you once a day and then when you get it (IF you can) see if there are anything that might help in the log in terms of why it was dropped?
