OmarAttaalla
Apr 14, 2018Aspirant
Ethernet connection on my Windows 10 desktop keeps disconnecting and reconnecting
I recently bought a Nighthawk R7000 router modem and whenever I would use ethernet connection on my desktop it would disconnect for a few seconds and reconnect every couple of minutes. I contacted s...
- Apr 30, 2018
Hi OmarAttaalla,
What is the firmware version of the router? Make sure it is updated.
OmarAttaalla
Apr 24, 2018Aspirant
Wifi also drops but for a shorter amount of time on my Windows 10 computer.
- JamesGLApr 30, 2018NETGEAR Employee Retired
Hi OmarAttaalla,
What is the firmware version of the router? Make sure it is updated.- OmarAttaallaMay 01, 2018Aspirant
Thank you, just updated my firmware and it hasnt disconnected so far.
- JamesGLMay 03, 2018NETGEAR Employee Retired
Hi OmarAttaalla,
You are welcome. Glad to know it is working now.
