Korin
Jul 18, 2022Follower
Ethernet cord doesn’t work
When I plug my Ethernet cord to both router and modem the green light doesn’t blink and it doesn’t detect any cables in the app how can I fix it?
Jul 18, 2022Guru - Experienced User
Not much to go on.
What Router and modem brand and model# do you have?
What CAT# lan cable are you using? CAT6 would be recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
