JRiggs
Jun 02, 2021Aspirant
Ethernet expansion slots on my netgear11?
I bought a netgear C6250 in Dec 2017 and love it. Problem is it has 2 slots in the back for ethernet cords. I use one for the internet and one for my VOIP home phone with OOMA. I need to expan...
JRiggs
I am not great with tech stuff, one other question. If I got either the 5 or the 8 slot does everything I need come in the box or do I need other connector cords/cables?
Thanks again, you're a lifesaver.
Jun 02, 2021Guru - Experienced User
It should have a power cord/supply.
the ethernet cords, you'd need to supply.
- JRiggsJun 02, 2021Aspirant
Thank you.
Will a Neargear GS 305 be compatable with my netgear C6250?
- antinodeJun 02, 2021Guru
Should be. Just like every other gigabit/s-capable unmanaged
Ethernet switch.Just don't get some fancier product whose model number has a suffix
(other than one like "v2" or "v3"). Like, say, GS305E, or GS305EP, or
GS305P, and so on. You don't need the additional features and
complexity.
