rustyone
Aug 26, 2021Follower
ethernet from router to EAX20
I am using a Router supplied by internet supplier it is a NF18ACV and a EAX20 (Purchased seperate), my question is am I able to use an ethernet cable from router to extender , The ethernet ports do a...
- Aug 27, 2021
yes you can hardwire the EAX20 into the router.
You just have to re-run setup and set it up in access point mode if you're going to have it hardwired in.
Aug 27, 2021Guru - Experienced User
