mpadhu
Dec 13, 2020Aspirant
Ethernet LAN disconnets intermittently - Netgear R6350 AC1750 Smart WiFi Router
Hi Guys, I own 'Netgear R6350 AC1750 Smart WiFi Router' which I purchased few months back. I face intermittent disconection of Ethernet LAN but Wifi works perfect. I am not able to find the patt...
Dec 14, 2020Guru - Experienced User
What firmware is on the router?
What modem/gateway is it connected to?
- mpadhuDec 14, 2020Aspirant
plemans wrote:What firmware is on the router?
Thanks for your reply. Currently on the version V1.1.0.64_1.0.1.
There is no modem. The ISP provides the demodulated signal via OFC.
- plemansDec 14, 2020Guru - Experienced User
theres a newer version of the firmware. I'd install that over a hardwired conneciton, factory reset the router, and reinstall.
plemans wrote:theres a newer version of the firmware. I'd install that over a hardwired conneciton, factory reset the router, and reinstall.
https://www.netgear.com/support/product/R6350.aspx#download
Thanks, Will do that. Any possibility of this issue getting resloved after upgrading the firmware?
