mpadhu
Dec 13, 2020Aspirant
Ethernet LAN disconnets intermittently - Netgear R6350 AC1750 Smart WiFi Router
Hi Guys, I own 'Netgear R6350 AC1750 Smart WiFi Router' which I purchased few months back. I face intermittent disconection of Ethernet LAN but Wifi works perfect. I am not able to find the patt...
mpadhu
Dec 14, 2020Aspirant
plemans wrote:What firmware is on the router?
What modem/gateway is it connected to?
Thanks for your reply. Currently on the version V1.1.0.64_1.0.1.
There is no modem. The ISP provides the demodulated signal via OFC.
Dec 14, 2020Guru - Experienced User
theres a newer version of the firmware. I'd install that over a hardwired conneciton, factory reset the router, and reinstall.
- mpadhuDec 14, 2020Aspirant
plemans wrote:theres a newer version of the firmware. I'd install that over a hardwired conneciton, factory reset the router, and reinstall.
https://www.netgear.com/support/product/R6350.aspx#download
Thanks, Will do that. Any possibility of this issue getting resloved after upgrading the firmware?
- plemansDec 15, 2020Guru - Experienced User
There's always the possiblity. its half the reason of firmware upgrades.
- mpadhuJan 13, 2021Aspirant
plemans wrote:There's always the possiblity. its half the reason of firmware upgrades.
Upgraded the firmware and test for around a month. The issue occured twice and I found that there is a power socket near the LAN wire. If I plug some load into that socket and turn the switch on, the LAN gets disconnected!. There is no relation between the two in any way but why this still happens?. I need to restart the router to make the LAN ports work.
Attached image for reference.
