Twint
Nov 27, 2022Follower
Ethernet land line
The light on the router That the Ethernet cable is hooked to is orange Should it be white like the rest of the lights?
microchip8
Nov 27, 2022Master
Orange/Amber means the link runs at 100 Mbps instead of 1 Gbps (white light). If you're sure the link should be at 1 Gbps, try different cables (CAT6 is recommended)
