it_no_work_now's avatar
Apr 08, 2017
Ethernet no longer working on R7000
My Netgear Nighthawk AC1900 Smart WiFi Router, Model R7000, Ethernet no longer seems to be functioning.    I can plug incoming ethernet cable into laptop and it is alive and well. WiFi signals are ...
  • it_no_work_now's avatar
    it_no_work_now
    Apr 16, 2017
    On phone with Support they had me hold in reset until the power light flashed 5 times. This did a factory reset on the router and the Ethernet functionality came back to life.
    Good result hot for the router, though interestingly we have coped well without it to the extent that connectivity seems batter without it - so much for extended range, higher speeds, etc.
    IAppreciate the help earlier, but I will mark this as the solution because this includes the details that got the device working again.
