it_no_work_now
Apr 08, 2017Aspirant
Ethernet no longer working on R7000
My Netgear Nighthawk AC1900 Smart WiFi Router, Model R7000, Ethernet no longer seems to be functioning. I can plug incoming ethernet cable into laptop and it is alive and well. WiFi signals are ...
- Apr 16, 2017
On phone with Support they had me hold in reset until the power light flashed 5 times. This did a factory reset on the router and the Ethernet functionality came back to life.
Good result hot for the router, though interestingly we have coped well without it to the extent that connectivity seems batter without it - so much for extended range, higher speeds, etc.
IAppreciate the help earlier, but I will mark this as the solution because this includes the details that got the device working again.
it_no_work_now
Apr 13, 2017Aspirant
I think I have a rock. Behaviour is the same even after the 30-30-30 reset.
I'll have a go at contacting tech support.
Thanks, Scott
it_no_work_now
Apr 16, 2017Aspirant
