lvthatlaugh
Dec 09, 2017Tutor
Ethernet not recognized
House electricity went out last night. Router would not recognize ethernet afterwards. Called internet provider -modem and ethernet cable working fine. Tried to reset router, didn't help. Performed lo...
- Dec 10, 2017Thanks! I'm actually an expert at turning them off and back on in the right order. Exchange my router for a new one and it worked fine. Obviously something went wrong with the power outage. Not sure why, we have a $65 surge protector. But wifi is on now and the family is happy once again!
michaelkenward
Dec 10, 2017Guru - Experienced User
The measures that William10a details are tje usual networ,m startup steps.
- Turn off and unplug the modem.
 - Turn off the modem router and computers.
 - Plug in the modem and turn it on. Wait 2 minutes.
 - Turn on the modem router and wait 2 minutes.
 - Turn on the computers.
It may be that your power outage killed something.
lvthatlaugh
Dec 10, 2017Tutor
- michaelkenwardDec 10, 2017Guru - Experienced User
Surge protectors are fine for some things. But they can't handle everything. It depends on the cause of the problem. I know from experience, that not much can stop a lightning strike, for example.
Too late now, but I should have suggested trying a spare power adapter for your old router. But you probably ended up with a shiny new router that adds more bells and whistles to your network.
