lvthatlaugh
Dec 09, 2017Tutor
Ethernet not recognized
House electricity went out last night. Router would not recognize ethernet afterwards. Called internet provider -modem and ethernet cable working fine. Tried to reset router, didn't help. Performed lo...
- Dec 10, 2017Thanks! I'm actually an expert at turning them off and back on in the right order. Exchange my router for a new one and it worked fine. Obviously something went wrong with the power outage. Not sure why, we have a $65 surge protector. But wifi is on now and the family is happy once again!
lvthatlaugh
Dec 10, 2017Tutor
michaelkenward
Dec 10, 2017Guru - Experienced User
Surge protectors are fine for some things. But they can't handle everything. It depends on the cause of the problem. I know from experience, that not much can stop a lightning strike, for example.
Too late now, but I should have suggested trying a spare power adapter for your old router. But you probably ended up with a shiny new router that adds more bells and whistles to your network.
