Filmrextm
Sep 23, 2021Follower
Ethernet not working
I try to use the ethernet port and all 4 ports not working i just buy it and setup only the wifi is fine but no ethernet
Sep 23, 2021Guru - Experienced User
What gateway/modem is it connected to?
Firwmare on the router?
have you tested the ports against itself?
https://kb.netgear.com/28408/WAN-or-LAN-port-not-working
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
how do you know the ports aren't working?
what actual error are you getting?
