Dmax32
Dec 22, 2020Aspirant
Ethernet ports flashing orange
Ok so my problem is I have a ethernet cable that runs from my main router into a secondary router with a cat 6 cable into my bedroom but I can only get 90 mbps in the bedroom but I get 200+ mbps on my...
schumaku
Dec 22, 2020Guru - Experienced User
Assuming the network cable is fine (all four pairs/eightstrands workable): Check make and model of the secondary router - well possible it has Fast Ethernet ports only. This is what the amber link LED are indicating.
Dmax32
Well the secondary router is a n300 router that isn't fast link capable but even when I connect my laptop to the secondary router's ethernet cable it still flashes amber.
