Dmax32
Dec 22, 2020Aspirant
Ethernet ports flashing orange
Ok so my problem is I have a ethernet cable that runs from my main router into a secondary router with a cat 6 cable into my bedroom but I can only get 90 mbps in the bedroom but I get 200+ mbps on my...
Dec 22, 2020Guru - Experienced User
What computer is it?
Does it have an gigabit ethernet port?
Have you checked the cable? Make sure its cat5e or greater.
Dmax32
The computer is a HP Omen with Realtek Gaming GbE Family controller adapter and all cables plugged into the main router is Cat 6
