DFunnell
Feb 04, 2020Follower
ethernet ports leds blinking red when ethernet cable connected
 The ethernet ports are flashing red when connected, is this correct if not what colour should they be and how  do I rectify the problem
- Feb 04, 2020
Google for the documentation of the router! Read and you'll see that red means its operating at 10 or 100 Mbps. White means it's operating at 1 Gbps (1000 Mbps).
If you have something plugged in that only supports 10/100 Mbps, then you'll get red
microchip8
Feb 04, 2020Master
