IDpotato2019
Jan 08, 2021Aspirant
Ethernet ports not working
Some of the ethernet ports on my router have stopped working. I did a factroy reset and it didn't help. Is there anything else to do? Thanks for your help.
IDpotato2019
Jan 16, 2021Aspirant
I was using a 4 port Netgear switch. It needed to be rebooted. Everything ok now. Thanks for your help.
antinode
Jan 16, 2021Guru
> I was using a 4 port Netgear switch. [...]
Not a very detailed description of that device. I've never seen a
four-port network switch. Five, yes. Eight, yes.
> [...] It needed to be rebooted. [...]
If you say so. Glad to hear that you got it working, in any case.
