FergyFerg
May 30, 2022Follower
Ethernet Ports not working
I have a nighthaw 4xs ac3200. My ethernet ports are not working. How can I troubleshoot to see if the ports are faulty? When I plug in any devices no lights come on
May 30, 2022Guru - Experienced User
Have you powered pulled the power adapter for 1 minute, press the power button to turn it off, then plug back in the power adapter, then powered ON the router with all wired devices disconnected from the LAN ports?
Swap LAN cables.
Try a factory reset and setup from scratch? Press the reset button for 10 seconds then release.
