JaeSeoul's avatar
JaeSeoul
Ethernet Switch -- Not Connecting Devices
Hello, I have currently have: - A modem - A router (Netgear Nighthawk R700) - An ethernet switch (Netgear GS105V5/5 Port) - A PC - A gaming console   Basically, I have the following connect...
  • antinode's avatar
    antinode
    Mar 26, 2020
    > - Maybe I can clear it up a bit (sorry):
       When I read "Basically", I expected trouble.
    > [...] There is also a green light that is constantly on above the
    > fourth port (on the right side).
       If a switch port indicates a connection when there's no connection,
    then I'd get a different switch.
    > - I tried plugging my cable that comes from the router to the switch in
    > every port. No lights came on. [...]
       If a switch port indicates no connection when there is a connection,
    >    Sounds to me like a bad switch.
       Still true.
