HGinDC
Apr 01, 2021Guide
Event Log has stopped recording events
Hello all. 1. First let me say that my moden is model CM2000, but the drop-down menu does not list that model so I selected the closest one (CM1000). 2. The moden is less than a week old and at ...
michaelkenward
Apr 02, 2021Guru - Experienced User
HGinDC wrote:
Hello all.
That can happen when you pick the wrong section for a message. The choice is section sensitive, although sometimes Netgear's database is incomplete. I would say that the CM2000 is too new to have entered the system, but a year?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I have no idea how much information the logs record in a modem only device. Most of the action on a network happens on the router, and that logs what goes on.
