opianosec
Aug 04, 2022Follower
Every day I experience the router R7000P disconnecting
Every day I experience the router R7000P disconnecting, the router reboots automatically, and the router is plugged into a new UPS, so power failure is not the issue.
The problem I am experienc...
michaelkenward
Aug 06, 2022Guru - Experienced User
Any pattern to this? Same time of the day?
The problem I am experiencing occurs at least twice a day after updating the firmware to V1.3.3.148_10.1.82.
No problems here with that version.
You could confirm that that is the problem by rolling back to the previous firmware.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Another option would be to reset the router and set it up from scratch. Backup the settings before you do that, just in case that isn't the issue and you want to reload them.
