jpldavidson's avatar
jpldavidson
Everytime I enable Smart Connect on my R8000, latest firmware, yes, with the same key
Everytime I enable smart connect the wifi stops connectiong. I guess I'm doing something wrong and anyone who knows what, I'd much appreciate some pointers as thats part of the reason I bought this ro...
  • yddtime's avatar
    Nov 05, 2019
    Smart connect creates more problems than it solves. I turn it off on every router I've ever owned. Part of the problem is that every client device behaves differently. Unless you only have a few types of devices that just happens to be compatible there will always be issues.
