goldlizsts
Jan 20, 2022Follower
EX2800 How do I make it work?
Tried to set it up, connected/plugged it into A/C source near router, pressed the buttons, ONLY 3 buttons lit up. The "DEVICE" button doesn't light up. What's wrong? What didn't I do right? I pressed the WPS buttons on both units.... the Netgear first, then the Router.... The "DEVICE" light just doesn't light up.
1 Reply
the device light is for when you connect a device to the extender. did you connect a phone or something to the extender?
