Tulsatime
Dec 02, 2020Tutor
EX6200 difficulty
I was doing a firmware update tonight. I think this thing is bricked. Upon power on the two network lights are amber and the connectivity arrows are flashing green. I cannot get the factory reset ...
- Dec 03, 2020
glad to hear it fixed it!
If you mark it solved, it might help the next person with that issue.
Dec 03, 2020Guru - Experienced User
You might be a candidate for a tftp or nmrpflash recovery.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- michaelkenwardDec 03, 2020Guru - Experienced User
One thing you could tryu before you go down tne TFTP road is the recovery reset.
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, a conventional firmware update may work. If it fails, then, as plemans says, TFTP is your friend.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities- TulsatimeDec 03, 2020Tutor
All great ideas! Thanks for the two tips...will be working on it today and will advise how it turns out.
The recovery reset procedure did not work. The TFTP did. I did a bit of reading through what you sent me...and it all worked as you said.
Kudos...much appreciated.
- plemansDec 03, 2020Guru - Experienced User
