Tulsatime
Dec 02, 2020Tutor
EX6200 difficulty
I was doing a firmware update tonight. I think this thing is bricked. Upon power on the two network lights are amber and the connectivity arrows are flashing green. I cannot get the factory reset ...
- Dec 03, 2020
glad to hear it fixed it!
If you mark it solved, it might help the next person with that issue.
Tulsatime
Dec 03, 2020Tutor
The recovery reset procedure did not work. The TFTP did. I did a bit of reading through what you sent me...and it all worked as you said.
Kudos...much appreciated.
Dec 03, 2020Guru - Experienced User
