dpl77
Sep 12, 2021Aspirant
Ex7000 won’t connect to mywifiext after making same name as network
How can I undo making the original “NETGEAR_EXT” the same name as my home network?
Sep 13, 2021Guru - Experienced User
what firmware version is on your EX7000? mesh was a feature added after it was initially released so if you're on early versions of the firmware, you'd need to upgrade.
If you're on the later firmwares, its called "one wifi" and can be enabled/disabled.
- dpl77Sep 13, 2021AspirantIt won’t let me connect to mywifiext.local to be able to check
- plemansSep 13, 2021Guru - Experienced User
Log into your router. In your router should be an attached devices list (or equivelent).
that'll have the extender's ip address (if you set it up).
Use that to connect/access the extender.
