dpl77
Sep 12, 2021Aspirant
Ex7000 won’t connect to mywifiext after making same name as network
How can I undo making the original “NETGEAR_EXT” the same name as my home network?
dpl77
Sep 13, 2021Aspirant
It won’t let me connect to mywifiext.local to be able to check
Sep 13, 2021Guru - Experienced User
Log into your router. In your router should be an attached devices list (or equivelent).
that'll have the extender's ip address (if you set it up).
Use that to connect/access the extender.
