xadd
Apr 06, 2022Tutor
EX7300 and R7800 : Certificate Error (Server identity can't be verified)
Hi, I have a R7800 router and EX7300 extender. Regularly, I have an error message on IOS device "The Server identity can't be verified". This message is not linked to a specific site, even i...
xadd
Apr 06, 2022Tutor
The Private WI-fi Address is disable on all my devices.
I must say that the problem appear on several distinct devices
Thank you for your help
Apr 06, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware is on the router?
3. what firmware is on the extender?
4. when does it happen? When connected to the router? when connected to the extender? Details are key
- xaddApr 06, 2022Tutor
HI,
The Router is connected to a TPLink TL-R470T+ Hub, connected to 4G Box
The R7800 router's firmware is V1.0.2.90
The EX7300 Extender's firmware is 1.0.0.146
I don't really know what is the connexion when it happens. It seems both was I'm either closer to the router or the extender..
Thank you
