DK-PA
Dec 03, 2020Follower
EX7500 KEEPS DISCONNECTING FROM INTERNET
Well this resolution cost me an extra $90; after spending $175 for this range extender. I am writing this to put this solution for FREE out in the public, and avoid someone else being overcharged f...
Dec 03, 2020Guru - Experienced User
I'd recommend just asking on here next time. Its free and that'd have been the top things we'd recommend.
1. firmware update/reset
2. manual install process and not using wps.
I recommend both of these quite frequently :)
If you do have issues again with the extender, ask on here. But I'd recommend using the proper forum for that specific device, you're in the router forum and not extender forum. it can get confusing at times with all the seperate forums.
