mmschumac
Jan 17, 2022Tutor
EX7700 and R700 are incompatible and Netgear support is unresponsive
I'm a network engineer in my professional life with extensive experience in wireless technologies. I've overall been very pleased with the R7000 router over the last few years but the EX7700 is a po...
Jan 18, 2022Guru - Experienced User
I'd try the 1.0.0.210 on the EX7700. I didn't see as much issues on that version as I did on the .222 version.
When you install it, try factory resetting and reinstalling.
The R7000 is more of a problem child. the MOST stable I've seen was the 1.0.9.42 version but that is significantly old.
But the R7000 has quite strong 3rd party firmware base. There's a lot of aftermarket one's for it.
I'd say try changing the ex7700's firmware first and see how it does.
mmschumac
Jan 18, 2022Tutor
Thanks again.
I downgraded to .210 a little over 2 hours ago and it’s been stable since. This is the longest period of stability I’ve had since installing the product.
I’ll post back after I’ve given this more time to burn in.
- plemansJan 18, 2022Guru - Experienced User
Here's hoping it stays stable for you!
