Bsphillips21
Aug 06, 2018Aspirant
Exclamation points-constantly having to reboot!!
Had router for approximately one year. About a month ago internet stop working (exclamation point on phone and home currently unavailable on televisions and tablets). After rebooting internet works a...
- Aug 14, 2018Changed the MTU?? To 1370 and have not had to reboot for 3 days!!! Hopefully that fixed it!!
DarrenM
Aug 10, 2018Sr. NETGEAR Moderator
What is the model of the router? did you hook up anything new to the network when the problem started happening? do you notice if the modem reboots or goes offline when you lose connection?
DarrenM
- Bsphillips21Aug 10, 2018AspirantThank you for the reply!
Model: r8000
Modem is good, hardwired to laptop and confirmed did not lose signal when exclamation points/ fire tv unavailable occur.
Did download the nighthawk and genie app on phone. I did fiddle around a little with vpn(enabled then unenabled) and access control with the apps. Just confirmed I do not currently have any devices on pause internet.
Thank you!- Bsphillips21Aug 14, 2018AspirantChanged the MTU?? To 1370 and have not had to reboot for 3 days!!! Hopefully that fixed it!!
