Dystopiate
Dec 20, 2020Follower
Expanding Wireless Access by Adding Another AP
Please forgive me if this has already been covered in another post. I couldn't find anything myself, and I looked around but get confused by the terminology. What I want to do is use my existing ...
Dec 20, 2020Guru - Experienced User
If you do run one of them as an AP (hardwired in) and use the same SSID, just keep in mind that they'll tend to be "sticky". meaning devices won't roam like a actual mesh system using the same ssid. Devices will tend to stay connected until the signal drops or is close to unusable.
