Windywave
Jan 13, 2021Aspirant
ExpressVPN on Nighthawk R6900 Wi-Fi Router
ExpressVPN offers firmware for the following Netgear routers: Netgear R6300v2 Netgear R6700v3 Netgear Nighthawk R7000 Netgear Nighthawk R7000P I would like to install the firmware on my Nighthaw...
- Jan 13, 2021
installing 3rd party firmware to a router that isn't the same is a good way to brick your device.
and you'd find more info on the expressvpn site for help installing their firmware to a stock router.
you're not going to find help on the official forums for installing 3rd party firmware
Jan 13, 2021Guru - Experienced User
Windywave
Rapid reply, plemens and good advice. I'll go there and see if they can answer.
