greghorm
Feb 26, 2021Aspirant
ExpressVPN on R7000 now I can´t access my router how to downgrad without access to web interface
I got ExpressVPN on R7000 now I can´t access my router how to downgrade without access to web interface. I use MACos. Tried reset, I don´t know how tu upload old FW. THX
greghorm
antinode wrote:> I got ExpressVPN on R7000 now I can't access my router [...]
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
@antinode thank you for being so nice and requesting deeper information about my problem. Can´t means that router webpage interface is not opening, no answering, tried on Mozilla, Chrome and Safari. Routerlogin.net is not responding, 10.0.0.1 is not responding.
Presumably, ExpressVPN came with some helpful documentation. Are you
following any actual instructions?
Yes, I spoke with expressVPN support and they said that I´ll not be able to acccess my original router interface after I upload expressVPN FW. It didn´t say before uploading, I would think twice or do adjustment that I need.
> [...] I don't know how tu upload old FW.
Presumably, the ExpressVPN documentation covers that, too.
You are wrong, they are not covering this, because NetGear is not their brand, but sure that you know about it from NetGear documentation.
Being polite and helpfull is rewarding!
Best regards and still looking for help and advice
antinode
Feb 26, 2021Guru
> [...] Routerlogin.net is not responding, [...]
Did you try "www.expressvpnrouter.com", as the ExpressVPN
documentation directs?
https://www.expressvpn.com/support/vpn-setup/app-for-routers-netgear/#setup
> [...] 10.0.0.1 is not responding.
What led to expect the R7000/ExpressVPN to respond at that address?
To what is your R7000/ExpressVPN connected? Some kind of modem or
other?
> [...] they said that I'll not be able to acccess my original router
> interface after I upload expressVPN FW. [...]
Right. After installing the ExpressVPN firmware, you'd be acccessing
the ExpressVPN interface, not the original Netgear interface. (Perhaps
at a different IP address.)
It's a safe bet that one of us is wrong about that.
https://www.expressvpn.com/support/troubleshooting/reset-original-firmware/
The hardware is from Netgear, but the ExpressVPN firmware is from
ExpressVPN, and you're dealing primarily with the firmware (whichever is
loaded at the moment).
