joebauers
Nov 09, 2022Follower
Expressvpn on R7450 router
Is it possible to install the ExpressVPN firmware on the R7450 router?
The best people to ask are at ExpressVPN.
They know which routers they support and Netgear is not going to help you with installing third party firmware.
You can also try this:
They have a list on their site of supported routers. The R7450 isn't one. However, Expressvpn is supported through ddwrt and it looks like its possible to flash it to that. Like michaelkenward says though, its a 3rd party process. its not supported on the official forums and if you brick your router, its on you.
https://www.expressvpn.com/vpn-software/vpn-router
