JonJL
Feb 16, 2022Tutor
Extender connecting to laptop via ethernet cable
My wife recently started a new job that requires her work laptop to connect to our internet via an ethernet cable (No WiFi). The router is located in the front of the house and her office is at the b...
Feb 16, 2022Guru - Experienced User
Powerline can be subject to interference.
Its why the actual speeds can be vastly inflated on powerline devices.
You can read a few rankings and tests on powerline to find out more.
https://www.smallnetbuilder.com/tools/rankers/powerline/view
The wn3000rp didn't work when hardwired into it?
Did other devices when hardwired into it?
JonJL
Feb 16, 2022Tutor
No it wouldn't, even when we set the computer to ethernet. I have never tried the wn3000 with anything else. The powerline doesn't affect the WiFi of all the other devices does it?
- plemansFeb 16, 2022Guru - Experienced User
powerline shouldn't.
I'd try the wn3000rp with other devices to see if it works or wasn't setup right.
