tikitiki
Nov 16, 2018Aspirant
Extender Issue After Firmware Update
Hi
If I update to the latest firmware (1.0.4.28) my EX6200 range extender has issues with the router. It will appear to be connected correctly from the EX6200 perspective (LED light on the exte...
- Nov 17, 2018
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
RANDD
Nov 30, 2018Aspirant
tikitiki After updating to 1.0.4.28 on the R8000, my EX7300 no longer resolved external network addresses on the 5ghz band, but I could hit any local address. When I switched over to the 2.4ghz, everything worked as normal. I tried all sorts of things to resolve it before finally hitting the factory reset. After getting everything set up again post factory reset, the extender is working as expected now. Hope your network setup isn't too complicated!
