Chriselliotlaug
Oct 30, 2020Tutor
Extender or Access Point or Router?
Hello, I have installed the EX7700 Extender and is extending my Wifi network successfully from my Virgin Media Router, now I am trying also to expand again my network to the summer house in my garde...
- Oct 30, 2020
to keep it simple:
Extender: a device that picks up a wifi broadcast and rebroadcasts it.
Access point: hardwired in via ethernet, powerline, moca adapters and broadcasts its own signal.
Bridge: it picks up a wireless broadcast but doesn't re-broadcast. It just lets you use the ethernet ports on the device.
If you've got a cable already ran, you want something to act as an access point. But most of netgears extenders (not all) have access point mode. As well as most routers have access point mode.
Oct 30, 2020Guru - Experienced User
AC1200 is a speed. which model did you buy?
did you set it up in access point mode (the one in the summer house)?
Is the wifi that's saying "connected no internet" for the devices connected to the extender in the primary home? Does it matter if the devices connect to the router? do they work?
Which virgin media router was it?
- ChriselliotlaugOct 30, 2020Tutor
Apologies, the externer I installed in the summer house was theModel: EX6120
plemans wrote:AC1200 is a speed. which model did you buy?
I am attaching the network drawing.
I have already installed and working: Virgin Media Router (Hitron model CGNV4) and the Netgear Extender EX7700 AC2200 Nighthawk X6 Tri-Band Wifi Mesh Extender.
To extend again the wifi network to the summer house in the garden as mentioned earlier I installed a CAT5 cable with about 15 meters, and now I an looking to understang what device I need to buy for the summer house?
An Extender, An Access Point, A Router with bridge mode?
- plemansOct 30, 2020Guru - Experienced User
to keep it simple:
