brguthrie
May 27, 2021Tutor
Extender recommendations for me
Have the AC1750 WiFi Router working okay with old extenders (Netgear Universal Dual Band Wfii Range Exenders model WN2500RP). Any recommendations on newer/better extenders to up grade to for speed/r...
- May 27, 2021
I'd highly recommend against using 3x extenders together.
Even more so if you're planning on daisy chaining them (connect 1 extender to the next).
I usually tell people, if they're needing more than 1 extender, to switch over to an actual mesh system like orbi or the MK system.
Extenders work great, but when you're using more than 1, it can cause instabilities/performance issues.
It might cost more to go with a mesh system but it pays off in terms of stability/speeds.
May 27, 2021Guru - Experienced User
A couple things.
1. AC1750 is a speed. Not a model. So not sure what router you have.
2. I'm a fan of triband extenders. Reason why is single/dual band extenders drop throughput 50%. Reason why is they have to use the same chip to go router----->extender and then extender------>device. And they can't do both at once. The triband extenders have a dedicated chip just for router----->extender communication. so they tend to have faster speeds, lower latency.
3. Most half decent dual band AC extenders will be a jump up from the wn2500rp. It was a pretty base model extender.
brguthrie
May 27, 2021Tutor
Thanks helpful, I was thinking these old extenders being basic (and maybe having only same dual use chip) might be good to just replace. Also, by doing that I'd saved a couple of bucks by just getting 3 new extenders vs. whole Obri setup, as My router Model 6350 while not super highend; I just purchased last month.
- plemansMay 27, 2021Guru - Experienced User
- brguthrieMay 27, 2021Tutor
Thanks again. Makes sense, and cost diff not really worth it. I'm going Obri -- this system deal for $599 seems what I will do. AX4200 WiFi Mesh System (RBK754) Orbi Tri-Band WiFi 6 Mesh System, 4.2Gbps, Router + 3 Satellites
I'll just eat the $129 for the AC1750 model 6350, and hold on to it for emerencies. I bought it in rush, when old Nighthawk got fried or died, and was not ready to think thru the mesh and Orbi.
thats a heck of a system. It'll have quite a bit more performance than your current system. Hope it works great!
If you have issues/questions with it, the Orbi AX forum is quite responsive and helpful.
Again, good luck!
