brguthrie
May 27, 2021Tutor
Extender recommendations for me
Have the AC1750 WiFi Router working okay with old extenders (Netgear Universal Dual Band Wfii Range Exenders model WN2500RP). Any recommendations on newer/better extenders to up grade to for speed/r...
- May 27, 2021
I'd highly recommend against using 3x extenders together.
Even more so if you're planning on daisy chaining them (connect 1 extender to the next).
I usually tell people, if they're needing more than 1 extender, to switch over to an actual mesh system like orbi or the MK system.
Extenders work great, but when you're using more than 1, it can cause instabilities/performance issues.
It might cost more to go with a mesh system but it pays off in terms of stability/speeds.
michaelkenward
May 28, 2021Guru - Experienced User
Try plugging your needs into the filters on the product pages:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
