rey3anthony
Aug 01, 2021Aspirant
Extender say up to 897 mg I have 1000
Hello friends, my internet is 1000 mg the extender says is up to 897 in wifi but in speed test just reach 100m with the extende wifi without the extended 300m I plug the ethernet cable from the exten...
Aug 01, 2021Guru - Experienced User
A couple things.
1. the ex6120 only has a 10/100mbps port. its not gigabit. So wired in, you'll max out around that 90-94mbps.
2. extenders cut throughput by 50% for single/dual band extenders. Reason why is they have to use the same chip to go router----extender and then extender-----device. And they can't do both at once. Hence the 50% speeed loss of what speed they're picking up.
3. 2.4ghz is much slower than 5ghz. but 5ghz signal drops off quickly with distance and obsructions.
- rey3anthonyAug 05, 2021Aspirant
so in order to reach my mission ... with this or other extender I can reach the 1000M that I already have?
- plemansAug 05, 2021Guru - Experienced User
Not sure exactly what you were saying here
my router is far from my computer maybe 100 FT I would like a extender with a ethernet port close to my computer and have close to 1000M that I already have , thats a dream or is posible?
