AlanGee57
Jan 20, 2022Aspirant
Extender will not reset to factory settings
Bought the EX8000 over a year ago, support helped me set it up, im terrible at tech, so was thankfull for that.
Recently installed a new Sy Router, tried to re-connect to network.
Problem now is:
Will not connect to network, just continuous flashing white lights, even using wps
tried to reset to factory settings, it will not reset.
All i have currently is an extender that is flashing white all the time.
Any suggestions?fixes?
You might have corrupt firmware.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
